1994 Ford Explorer Slippage in cold weather.
FORD94WIS
  • 1994 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 186,000 MILES
I live in Wisconsin and it's winter season right now. The problem started when the cold weather set in.
When I park the Explorer for more than 6 hours, then go to start it, put the shift into drive it seems like first gear won't engage & the transmission stays in neutral for about 10 seconds. None of the gears work at this time. The only thing I can do is shift back into PARK and then try to shift into DRIVE again. Sometimes it will engage into first and other times I have to redo the whole process. The other situation is when I'm approaching a stop sign/red light I can hear the transmission decellerating, but there's no grinding. Is there a simple fix or is there an additive that I can use? How long before the transmission will go out completely if this problem persists? Please send your comments or recommendations. Thank you. ~Ford94wis
Sunday, February 14th, 2010 AT 5:50 PM
  • 109,885 POSTS
First, if the trans works good when it warms up, chances are there is a problem with the seals in the trans. What I recommend is servicing the trans and then adding an additive that is designed to soften o-rings / seals. In the transmission. There are several good ones available.
Let me know if it helps.
Sunday, February 14th, 2010 AT 11:10 PM
