1994 Ford Explorer running rough at idle/low power
200,000 MILES • 6 CYL • 4WD • AUTOMATIC
JEFF CASPER
had bad misfire, checked all plugs. found #4 had major buildup around ceramic insulator. was preventing from firing. replaced plugs and engine still running rough and almost dying. think it could be egr valve stuck. need other info if possible. thanks.
Dec 10, 2009 at 8:38 AM
  • 110,248 POSTS
Is it a dead miss all of the time or does it run good at times? Has the check engine light come on?
Dec 10, 2009 at 1:13 PM
