Engine Mechanical problem
1994 Ford Explorer 6 cyl Two Wheel Drive Automatic
When im driving on the highway ive noticed at 55mph or so the rpms dont wont go any higher than about 2k unless i punch it. I can tell its not as peppy but i still am able to speed up the without any problems but after i let off the gas the rpms will shoot up a few hundred then drop right back down. It also seems sometimes when im goin fast the rpms will go up a little then right back dowm. I got the truck from an older woman who didnt drive very much it only has 80k miles. So I recently went to do a tune up but everything looked clean so i just flushed the raditator, changed the thermostat, pcv valve, tranny fluid... I thought the problem could be from the fuel filter and i havent changed than yet because i havent had a chance to get the tool. If also noticed every now and then for some reason when i crank it it will shake a little and then when i give it gas it will die down after about 30 seconds or so. So sorry about the long message but i was wondering if you guys would know of any reason why it would do these things.... Thanks
Nov 5, 2009 at 10:35 PM
