Passenger side window does not go down, motor sounds like its working but nothing happening.
Back passenger window will go down but not up.
Today the driver side window is acting like the passenger side but will go down and up if you keep pushing on the switch.
The only window working is the back on the driver sides.
Took that switch out and placed it on the passenger side thinking and hoping I had 3 bad switches but it didn't not work.
Do I have 3 bad motors?
the back window that is working sounds like it might be going out as well....works slowly.
thanks..Dan
thanks..Dan
Jun 11, 2008 at 2:43 PM
