1994 Ford Explorer OIL PRESSURE
DEXTER KILLINGSWORTH
  • 1994 FORD EXPLORER
  • 6 CYL
  • 4WD
  • MANUAL
  • 17,500 MILES
No oil pressure. New oil pump installed 2 yr. Ago. No engine noise presently but afraid to operate under circumstances. Sending unit replaced but did not correct. Would engine flush correct?
Tuesday, July 21st, 2009 AT 9:37 PM
  • 109,896 POSTS
If you have no oil pressure, the engine will be knocking and ticking and eventually lock-up. IF you hear nothing, there is a problem either with the gauge, (you replaced the sending unit), or the wiring from the sending unit.
To confirm, go to a nationally recognized parts store to get an oil pressure gauge. Most will lend or rent them. Unplug the sending unit and replace it with the manual gauge the is rented. Start the engine. This way you can assure yourself that you are getting pressure.
Let me know what you find, or if you have other questions.
Tuesday, July 21st, 2009 AT 10:51 PM
