1994 Ford Explorer OIL PAN REMOVAL
159,000 MILES • 6 CYL • 2WD • AUTOMATIC
MINISTERCOLLAZO
ALL OIL PAN NUTS ARE 10MM WITH EXCEPTION OF ONE. ON THE FRONT LEFT OF OIL PAN THERE IS ONE SCREW,NUT WHATEVER IT IS THAT IS DIFFERENT THAN OTHERS.. IT IS ROUND WITH HOLE IN CENTER. ALLEN WRENCH, TORGUE BITS ,AND HEX BIT WILL NOT REMOVE IT OR FIT. IS THIS A GUIDE IF NOT WHAT IS IT? HOW DO I REMOVE IT? ( FIRST BOLT ON THE LEFT FRONT )
Feb 7, 2010 at 1:09 PM
BLUELIGHTNIN6
  • 16,542 POSTS
have to lift engine out to replace engine oil pan on the '94 explorer..you talking about tranny or engine pan?
Feb 9, 2010 at 5:06 PM
