I bought this vehicle new and this vibration noise in the front right tire started...sounds like a rubbing noise....when I bought new tires. After having it realigned, balanced etc I had another set of tires put on & it improved somewhat but still persisted. I had all tires rotated & the noise has gotten progressively worse.You can hear the noise as the tire goes around.
Could it be a bearing or brake rotors??
Thanks,
Thanks,
Jun 26, 2010 at 11:03 AM
