1994 Ford Explorer No Power
180,000 MILES • 6 CYL • 2WD • AUTOMATIC
FRANCHISELOBO
My explorer when i reach between 45 and 50 mph... will not shift into a higher gear, the rpm's just continue to go up, and to reach this speed, it takes me a while, i have a big lack of power. The oil was just changed within the last 1000 miles. Can anyone help!
Feb 27, 2009 at 3:09 PM
JGAROFALO
  • 489 POSTS
Sounds like a stuck governor. If you can manually shift it into 2nd by placing the selector lever in the "2" position to manually upshift, then it is either a stuck gevernor or sticking shift valves in the valve body.
Feb 28, 2009 at 11:50 AM
