1994 Ford Explorer
The last time I was on here I receive some very great info from a great mechanic. He told me what the 2 codes meant that Pepboys Auto pull back in July from my truck.
332-Knock Sensor
335- Crankshaft Postion sensor
I havent yet to get it fix.. I'm so confuss. I have heard lots of different folks tell me that I may not need Knock Sensor, it's the Crankshaft. However my check engine light is still on. This happen right after having new module install. I have had many new parts install, and the problem still isn't fix. I taken my car to see if it would pass emission testing, and it actually did w/ the check engine light on. I notice my car was running sort of poorly. Yesterday, tried to turn it over, and it wouldn't start. It has plenty power when I turn it over, but will not crank. This was the very same problem I had in very beginning, I was told it was the crank sensor.. I purchase & had that place on car. It crank after that, but now it's back to same result. It has to be something else now because I have already place crank senior. Any suggestions. I can't even get my car start to go to a shop.
332-Knock Sensor
Oct 28, 2010 at 2:32 AM
