MAP sensor location - I have problems
RAYAVILA
  • 2013 FORD EXPLORER
  • 3.5L
  • V6
  • 4WD
  • 101,000 MILES
Where is located MAP sensor? Any diagram or picture?
Sunday, August 2nd, 2020 AT 8:05 PM
  • 110,182 POSTS
It is located at the top of the air intake. I attached a picture. Let me know if this helps. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Sunday, August 2nd, 2020 AT 9:30 PM
RAMONAKELLEY
  • 2001 FORD EXPLORER
Engine Performance problem
2001 Ford Explorer 6 cyl Four Wheel Drive Automatic
our car is losing power at 4000 rpm, s
Wednesday, October 14th, 2020 AT 2:12 PM (Merged)
CARLIFE65
  • 200 POSTS
Inspect your ignition coil adapter,and also kickdown cable, could be incorrec cable adjustment.But to me it sound like your catalytic converter is clogged,,or faulty.
https://www.2carpros.com/forum/automotive_pictures/420105_5_6.jpg
https://www.2carpros.com/forum/automotive_pictures/420105_00071_catalytic_converter_1.jpg
https://www.2carpros.com/forum/automotive_pictures/420105_00623_trans_control_solenoid_1.jpg
EDNA4GIRLS
  • 1994 FORD EXPLORER
Electrical problem
1994 Ford Explorer 6 cyl Four Wheel Drive Automatic
I am trying to get a diagram of where to find the map sensor on my explorer. So that my husband can found out what the part number is and to go to Checkers and get a new one, because Checkers can not sell us one un til we bring in the the one that is in there right now and we can't find out where to even look, because are not gettinga ny answers from ford or any one else on where to even start to look, because they want us to bring it in to them, so that they can charge us $80. Plus dollars to just tell us where it is and that is not even asking to change the sensor!
Edna
Wednesday, October 14th, 2020 AT 2:13 PM (Merged)
OBXAUTOMEDIC
  • 3,711 POSTS
Hi Edna,
If I may ask what problems are you having?
And also Ford does not have a MAP Sensor . They have what is called a Pressure Feedback EGR Sensor and it looks like this....
https://www.2carpros.com/images/question_images/199295/original.jpg
It is located on the drivers side of Plenum about midway.
MAYS
  • 1992 FORD EXPLORER
Electrical problem
1992 Ford Explorer 6 cyl Four Wheel Drive Automatic
what are the problems cause by a map sensor failing
  • 31,937 POSTS
Hi there.
MAP SENSOR DRIVABILITY SYMPTOMS
Anything that interferes with the MAP sensor's ability to monitor the pressure differential may upset the fuel mixture and ignition timing. This includes a problem with the MAP sensor itself, grounds or opens in the sensor wiring circuit, and/or vacuum leaks in the intake manifold (airflow sensor systems) or hose that connects the sensor to the engine.
Typical drivability symptoms that may be MAP related include:
* Surging.
* Rough idle.
* A rich fuel condition, which may cause spark plug fouling.
* Detonation due to too much spark advance and a lean fuel ratio.
* Loss of power and/or fuel economy due to retarded timing and an excessively rich fuel ratio.
A vacuum leak will reduce intake vacuum and cause the MAP sensor to indicate a higher than normal load on the engine. The computer will try to compensate by richening the fuel mixture and retarding timing -- which hurts fuel economy, performance and emissions.
Mark (mhpautos)
