1994 Ford Explorer Knocking sound
133,000 MILES • 6 CYL • 4WD • AUTOMATIC
JUSTIMC
When I turn on the car it knocks after about 15 sec then it knocks when I drive it. The oil gauge is in the normal range but low by the n in normal.
Mar 1, 2008 at 3:23 PM
MERLIN2021
  • 17,250 POSTS
Usually a rap in the engine block area means a bad connecting rod bearing and crank journal...or a bad wrist pin. Either way it would require a tear down or engine replacement to fix, my advice, drive as is...
Mar 1, 2008 at 11:53 PM
