1994 Ford Explorer key
JMURRAY3629
1994 Ford Explorer 4 cyl Four Wheel Drive Automatic
my key broke and i don't have another one. it didn't break in the ignition. Autozone sells the key tumbler i just don't know how to put it in. can you help?
May 16, 2009 at 12:24 AM
JGAROFALO
  • 489 POSTS
[quote:386e3299e1="jmurray3629"]1994 Ford Explorer 4 cyl Four Wheel Drive Automatic
my key broke and i don't have another one. it didn't break in the ignition. Autozone sells the key tumbler i just don't know how to put it in. can you help?[/quote:386e3299e1]
With the remains of the key in the switch, there is a pin on the bottom of the tumbler housing that will release the tumbler with the switch in the "ON" position. Without the key, the pin will have to be drilled out, and it is VERY hard!
May 17, 2009 at 3:37 AM
