1994 Ford Explorer- Jolts/jumps when in Drive
BLONDYGIRL8905
Hi, I bought my 94 Explorer used from a private seller in June 06. Everything was fine until about 2 months ago... When I am in drive, my truck will lunge forward.... about every 3-5 seconds this will happen. The tricky thing is... only when the truck is warm. I asked one of the mechanics in my family, he told me to have to fuel filter replaced... but now that I've done that... it STILL does it! I don't know what to do? Any advice would be very much appreciated!
Nov 17, 2006 at 9:13 AM
ECGRANT
i have a similar problem... did you solve yours?.. ecgrant (loucgrant@aol.com)
Dec 21, 2020 at 3:29 AM
MERLIN2021
  • 17,250 POSTS
If the check engine light has come on get the codes read, Does it idle smooth? You can try a q-tip wet with alcohol to clean the MAF heated wire. Do it with the engine off!
