1994 Ford Explorer IT KEEPS RUNNING HOT
AZUREAZURE
Engine Cooling problem
1994 Ford Explorer 6 cyl Two Wheel Drive Automatic
TURN OFF A/C TEMPERATURE DROPS. RUNS HOT WHILE A/C IS ON. CHANGED THERMOSTAT AND RADIATOR CAP. ADDED COOLANT AN TOPPED OFF FLUIDS AND CHANGED OIL. IS MY WATER PUMP BAD?
Jun 18, 2010 at 3:04 PM
  • 75,988 POSTS
Does it have an electric fan for the AC condenser if so is it coming On?
Or does it have a fan clutch if so check its operation, radiator if its clogged and the water pump circulating coolant while you look into the opening-could also be airlock
Jun 18, 2010 at 3:47 PM
