1994 Ford Explorer idle
1994 FORD EXPLORER
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
JIM MAHONEY
i sprayed throttle cleaner into throttle body passage
and even took idle air sensor off and soaked it in cleaner but the engine still idles eratically.the engine revs up and comes down at evenly timed intervals.what should be my next coures of action.
thank you very much.
Nov 5, 2008 at 9:03 PM
SERVICE WRITER
  • 9,123 POSTS
Finding the codes would be a good idea, as it may lead you to the problem. I have seen mass air flow sensors get dirty or go bad on these. I would start with the codes first.
Nov 5, 2008 at 9:06 PM
