1994 Ford Explorer help
ALUCARD47932
Engine Performance problem
1994 Ford Explorer 6 cyl Four Wheel Drive Automatic
my truck will start and run, after drivinhg it several blocks it dies. restarts then has idling problems and dies. i have given it a tune up, new pcv valve, fuel filter, and air intake control sensor. it isnt throwing a check engine light. any ideas? the model is a 94 the trans is a 94 the engine is out of a 95 put in inapril of 09 .
Jan 7, 2010 at 11:25 AM
  • 75,988 POSTS
Check the fuel pressure fuel pump could be on its way out-
Jan 7, 2010 at 12:27 PM
