My 1994 Ford Explorer gas gauge does not work. I am not sure if its related to the problem I am having. When I fill up the gas tank and drive the car runs fine. When I get around 100 miles or so on the odometer, the truck will start to feel like its going to stall. Then the fuel pump fuse will blow and the truck will not start til I put more gas in it. Once I fill the gas tank back up and replace the fuse, it runs perfect. When this happens the tank is still about have filled? Any help would be appreciated, thanks.
Aug 19, 2009 at 11:50 PM
