1994 Ford Explorer fuel
JIMM1ON1
Engine Performance problem
1994 Ford Explorer 6 cyl Two Wheel Drive Automatic
im tring to locate the fuel pump fuse before i take the fuel pump out find out its just a fuse
May 9, 2009 at 3:00 AM
JGAROFALO
  • 489 POSTS
[quote:ca5f6af0b0="jimm1on1"]Engine Performance problem
im tring to locate the fuel pump fuse before i take the fuel pump out find out its just a fuse[/quote:ca5f6af0b0]
The fuse and relay are located in the power distribution box under the hood. The fuel pump fuse is the #1 fuse, and should be a 30 amp fuse. Don't overlook the relay. This can fail as well as the fuse.
May 10, 2009 at 12:48 AM
SQUARED
  • 6 POSTS
what syptoms are u having that u think it could be a fuel related problem like that?
May 11, 2009 at 11:29 AM
