Engine Performance problem
1994 Ford Explorer 6 cyl Two Wheel Drive Automatic
im tring to locate the fuel pump fuse before I take the fuel pump out find out its just a fuse
Saturday, May 9th, 2009 AT 10:00 AM
JGAROFALO
MECHANIC
The fuse and relay are located in the power distribution box under the hood. The fuel pump fuse is the #1 fuse, and should be a 30 amp fuse. Don't overlook the relay. This can fail as well as the fuse.
SPONSORED LINKS
Sunday, May 10th, 2009 AT 7:48 AM
SQUARED
MEMBER
What syptoms are u having that u think it could be a fuel related problem like that?
