1994 Ford Explorer Freeze Plugs
1994 FORD EXPLORER
KEVRHEA
Engine Mechanical problem
1994 Ford Explorer 6 cyl Two Wheel Drive Automatic 200.00 miles
i've changed the water pump and the timing belt cover gasket, now i'm leaking water from the front driver side freeze plug, do not know how to replace the front freeze plug.
Apr 8, 2009 at 6:28 AM
  • 110,244 POSTS
If you have access, they are easy. Just take a punch or straight screwdriver, poke a hole in the plug and pru it out. Make sure to drain the coolant or you will get wet. Clean the opening and take a new one, and tap it into place. I always use a small 2x4 to keep it straight and flush so it doesn't go in on an angle. Then I tap on the wood.
NOTE: If you would rather, they make a rubber plug replacement. You slid it in and tighten a nut on it until it tightens in the hole.
Apr 8, 2009 at 10:31 AM
