1994 Ford Explorer Fluid Eater
160,000 MILES • 6 CYL • 4WD • AUTOMATIC
MIKEZIG
My sons 1994 Ford Explorer has needed about 4 1/2 quarts of transmission fluid over the past month. The strange thing is, is that it isn't leaking a drop. Where is the fluid going?
The tranmission will slip when it's about a quart low but if I top it off to full it seems to be fine for about a week.
I don't smell any burning and the fluid color is nice and red and smells clean.
Mar 17, 2009 at 10:50 AM
BLACKOP555
  • 10,386 POSTS
do you notice white exhaust? how bout low power steering fluid levels? any leaks of oil anywhere? oil in coolant or coolant in the tranny oil? check at the output shafts of the tranny, is there fluid around there?
Mar 17, 2009 at 2:02 PM
