1994 Ford Explorer Engine running
12,600 MILES • 6 CYL • 2WD • AUTOMATIC
MM023466
Engine started to run rough, idle high and use excessive gas
Dec 23, 2007 at 6:25 AM
BMRFIXIT
  • 19,053 POSTS
[quote:9388f1968e="mm023466"]Engine problem
1994 Ford Explorer 6 cyl Two Wheel Drive Automatic 126,00 miles
Engine started to run rough, idle high and use excessive gas[/quote:9388f1968e]
i ask how is the tune up on it
check for tune up check coil pack
check for vacuum leak
check thermostat
Dec 23, 2007 at 1:48 PM
