1994 Ford Explorer engine problem
132,654 MILES • 6 CYL • 4WD • AUTOMATIC
STARMAN1950
engine runs fine, but after restart 10 mins later when warm runs real rough then clears up, runs fine no check engine lights coming on. possible bad fuel injector problem. thanks
Mar 28, 2009 at 6:24 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Very likely injector leaking causing a hot soak condition. Put a bottle of TECHRON in tank it may clean up pential and save you an injector cleanig bill.
Thanks for Donate
Mar 28, 2009 at 6:52 AM
