1994 Ford Explorer engine missfires
184,000 MILES • 6 CYL • 4WD • AUTOMATIC
FLYSTIGUY
i Have just replaced the intake manifold gasket on my 1994 ford explorer. in doing so i reinstalled the fuel injectors with seals and caps. i just started it up and it missfires like crazy. ive checked the plugs, wires, vacuum lines i just do not know where to go from here
Mar 25, 2010 at 10:41 AM
  • 75,988 POSTS
Engine running rough or misfiring can be cause by the following-inspect and test all the following below:
1.Defective spark plug.
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
Mar 25, 2010 at 12:46 PM
