1994 Ford Explorer ENGINE
175,000 MILES • 6 CYL • 2WD • AUTOMATIC
SMELCHOR1967
MY ENGINE WONT START IT SOUND LIKE THE ALARM OR ANTI THEF IT GET ACTIVATE THEN ? BY DISCONECT THE NEGATIVE CABLE FROM BATERY AND WAIT FIVE MINUTES CAR WILL START?
Apr 14, 2010 at 4:14 PM
DAVE H
  • 13,383 POSTS
TEST E - VEHICLE WILL NOT CRANK
Insert door key and turn to unlock position. Remove key and open door. With ignition off, check warning indicator. If indicator is flashing, go to next step. If indicator is not flashing, perform step 2) in TEST A , then go to next step.
Measure battery voltage. If voltage is more than 9 volts, go to next step. If voltage is less than 9 volts, service battery as needed and retest system.
Measure resistance between pins No. 12 and 24 of control module. If resistance is more than 100 ohms, replace control module and retest system. If resistance is less than 100 ohms, anti-theft system is okay, problem is in vehicle starting system.
Apr 14, 2010 at 8:44 PM
