1994 Ford Explorer Electrical Malfunction
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
LIONEL_LAMPKIN
Last night I tried to connect my personal stereo and in the process I blew the 15 amp fuse in the fuse box three times, replacing it three times. This morning I started the car and notice that the lights on the over head console were flickering, next I notice that the ABS light was illuminated and the battery and rpm gauge was not indicating/working. Shortly after driving off the battery just went limp, like all of the juice had just been drain. Could you please advise me on next step (I've checked all the fuses and fuse boxes, interior and under hood).
Thanks for the hand up, Good bless
Lionel
Oct 19, 2010 at 5:39 AM
JDL
  • 16,098 POSTS
Usually with vehicle running, it's the alternator that carries the system. Use a voltage tester at the fuses, if you haven't already. Even if the fuse is good, if there is no voltage, the circuit is dead. Battery has a full charge and all connections are good.
Oct 19, 2010 at 7:30 AM
LIONEL_LAMPKIN
Thank you JDL. I haven't had the chance yet to really look into the problem further, so this will be my first course of action when I get home.
Lionel
Oct 19, 2010 at 7:46 AM
