1993 Ford Explorer relays
RONMONGAN
  • 1993 FORD EXPLORER
  • 4 CYL
  • 13,000 MILES
On your great web site found a photo of the
fuse box, to check fuses.
Does the air conditioning electrical system have
relays, or can I just check fuse, and
follow the electrical wiring to find a possible short?
A shop told me all equipment was well but hot air
appears to be an electrical problem.
Thank you for your help.
Thursday, August 19th, 2010 AT 11:15 AM
BLUELIGHTNIN6
  • 16,542 POSTS
If the air flow is good but the air is just warm it's probably not an electrical issue unless this has automatic a/c system instead of a manual system. Only relay for the A/C system is the blower motor relay which has nothing to do with the temperature of the air.
Thursday, August 19th, 2010 AT 4:11 PM
