1994 Ford Explorer Confused
SHIITAN
Engine Cooling problem
1994 Ford Explorer 6 cyl Four Wheel Drive Automatic 140K miles
I need help with an over heating problem. On 7-5-10 my girlfriend was driving it and it over heated. The outside air temp was 103. My friend looked at it and he said the coolant resovor boiled over. I replaced the water pump, fan, fan clutch, thermostat (with the copper button toward the engine), radiator, all hoses, oh, and the radiator cap. I didn't see any coolant in the oil, so I don'y think the head is cracked or the head gaskit is bad. What do I do next? Please HELP.
Jul 7, 2010 at 9:46 PM
  • 75,988 POSTS
Could be airlock in the system try bleeding it out don't work get it block and pressure tested.
Jul 8, 2010 at 12:11 AM
