1994 Ford Explorer Codes
196,000 MILES • 6 CYL • 4WD • AUTOMATIC
KNACK0125
  • 6 POSTS
I recently pulled codes from my 94 Explorer Limited and didn't know how i should then go about fixing the problems. Since when you look up the codes online it doesn't tell you how to fix it, just what the issue is.
It gave me between 2 tests (KOEO and KOER tests) 327 came up in both tests (3 times between the 2 tests) for the EGR vlavle position or Exhaust Pressure Transdeucer circuit below minimum voltage.
565 for Canister Purge circuit failure
538 for Insufficient RPM change during dynamic responce or goose test KOER or invalid cyclinder balance test due to Cylinder Identification sensor failure.
I am hoping to get it back up and running so it can be used again or sold since its only been a money pit.
Aug 29, 2010 at 3:46 AM
WRENCHTECH
  • 20,760 POSTS
Are you having a problem starting the vehicle because none of these codes would cause that.
Aug 29, 2010 at 4:06 AM
KNACK0125
  • 6 POSTS
I have always had some issues with starting when i was running it, just took a second or 2 to start not an immediate start up. Only recently had an issue due to the battery going bad after letting the explorer sit for 8 months. I know there is an issue due to how it was driving.
I was having issues with holding power at highway speeds. Always having my foot to the floor i believe, and some times issues with getting up to speed quickly. If i remember correctly also was having an issue with shifting properly.
I also noticed my braking system is out of wack and had replaced the pads only 9 months i believe after putting them on so i think there is an issue with my abs also. I hear a spoing sort of sound when i put the brakes on at low speeds, around 5 mph, right before stopping.
Its not registered or inspected now so i can't drive it on the highway to test it legally. I didn't want to stop running it, was going to trade it in on the clunkers but couldn't get decision made to do it.
So instead of fixing the explorer and keeping it running, just have let it sit and drove a small car with no power to get me to school and work.
Aug 29, 2010 at 9:04 AM
WRENCHTECH
  • 20,760 POSTS
It sounds like your going to have to get it inspected. The info you have doesn't tell me too much, especially since you can't drive it.
Aug 29, 2010 at 9:22 AM
KNACK0125
  • 6 POSTS
I did take it for a short test drive around the block to get the engine warmed up but nothing above 30mph and it was having issues holding rpm when driving on the highway. I didn't know if it would pass at all for the inspection so hoped to fix it first, inspect later. I can look into getting it al setup with registration and so i could drive it on the highway.
Do you know what the codes i gave are connected to? Obviosly what is stated on the reader or online, but don't know parts that would intersect with them since i'm no mechanic.
Sep 1, 2010 at 12:37 AM
WRENCHTECH
  • 20,760 POSTS
The EGR system needs to be troubleshooted further and the canister purge valve circuit needs to be tested.
The 538 code is probably just a problem with the way they performed the code test.
Sep 1, 2010 at 1:30 AM
KNACK0125
  • 6 POSTS
As far as the testing of it, i did it myself with a tester, i could have done it wrong with putting my foot down on the pedal and letting it back up again.
So it sounds like i need to take it to a garage and have them take it apart and look it over. Most likely the best solution i sappose.
I also was wondering with the wiper system, it doesn't want to turn off after i turn it on for a short instance. Like to just get dew off, and i had replaced the switch itself and it did not help. Any suggestions on that front would be help also. Thanks
Sep 1, 2010 at 2:33 AM
WRENCHTECH
  • 20,760 POSTS
You probably want to start another question for that issue.
Sep 1, 2010 at 2:55 AM
