Yes - After changing both Oxygen Sensors, ($105) (one on each exhaust pipe behind the manifold), replacing the EGR Valve, ($47) and EGR Vacuum Solenoid, ($65) all without correcting the problem I ended up purchasing an OBD I Code Reader at the auto parts store for $29. I should have done that first, it would have saved me a couple hundred bucks.
The codes came up to replace the Fuel Pump Relay, ($6) (located in the fuse/relay box under the hood on the passenger side), and the EGR Valve Sensor, ($57) (rectanguler metal box with one plug and two small hoses, mounted to a bracket on the intake manifold, drivers side, directly behind and slightly above the A/C compressor).
After spending an entire day turning wrenches and driving to the auto parts store for parts that didn't fix the problem, the correct fix only took about 15 minutes. I would try the Fuel Pump Relay and EGR Valve Sensor first, they are easy to get to and relatively cheap. Good Luck.
Jan 6, 2021 at 6:35 AM
(Merged)
