1994 Ford Explorer clutch slave cylinder
156,000 MILES • 6 CYL • 4WD • MANUAL
ROLL
i was just wondering if you could tell me the easiest way to remove the line from the clutch slave cylinderi dont have the tool but i was told i could use a thin screwdriver to pop the line out.
thanks
Jan 3, 2008 at 6:34 AM
ARTMANG
  • 61 POSTS
just use a thin nail screw driver or just something hard and thin to be able to push out the small cilinder clip.i use a thin nail and gently tap it with a hammer till it comes out half way then ill just pull the rest out with pliers.
Jan 4, 2008 at 4:26 AM
