Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Engine
Serpentine Belt
Tensioner
1994 Ford Explorer CHANGING ALTERNATORE
1994 FORD EXPLORER
500,000 MILES • 6 CYL • 2WD • MANUAL
FORD1994EXPL
MEMBER
1 POST
WERE IS IS THE BELT TENSION ER AND WHAT SIZE O WRENCH DO I NEED
Feb 15, 2010 at 8:01 AM
Experienced Mechanic
Here is a routing diagram to help you locate the tesnionier:
https://www.2carpros.com/car_repair_information/year/1994/make/ford/model/explorer/1994_ford_explorer_drive_belt_routing_diagram.htm
As far as the bolt size, some are 15mm, some use a 3/8" ratchet end or 1/2" ratchet. There are different ones. Sorry I can't give you the exact without being there.
Feb 17, 2010 at 1:09 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
