1994 Ford Explorer broken ball joint
175,000 MILES • 6 CYL • 4WD • AUTOMATIC
STRAZMULACK
how can I remove a broken lower ball joint that has been sheared off below the knuckle
Jan 31, 2010 at 9:25 AM
  • 110,251 POSTS
CHances are you are going to need a big hammar. Honestly, if it is broken below the knuckle, you will need to beat it out unless it's threaded into the control arm, but I don't believe this vehicle is.
Feb 1, 2010 at 12:19 AM
