1994 Ford Explorer Brakes to the floor
BCHETH78
  • 1994 FORD EXPLORER
  • 6 CYL
  • 65,000 MILES
I have a 1994 Ford Explorer with 65000 miles. Every couple of weeks I will be driving it. When I shut it off and then return to it and start it up again the brake pedal goes all the way to the floor as if I had air in them. I will try pumping them, but that does not help. Also, It normally happens when my tempature gauge shows the truck is starting to get hot. What is it and how can I fix it?
Friday, September 10th, 2010 AT 11:00 PM
  • 109,885 POSTS
Are you leaking any brake fluid from any hoses or wheels? Is the fluid level full?
Friday, September 10th, 2010 AT 11:51 PM
BCHETH78
I checked the brake fluid twice and its full. I have'nt had a chance yet to double check the hoses. The wierd thing is it only happens approx every 2 weeks and usually when it's hot.
Saturday, September 11th, 2010 AT 2:45 PM
  • 109,885 POSTS
If there are no leaks, I would recommend checking all 4 wheels for leaks at the calipers and the wheel cylenders. If they are dry, then the problem must be coming from the master cylender.
Let me know what you find.
Monday, September 13th, 2010 AT 7:22 AM
