1994 Ford Explorer brakes
JDC_62000
  • 1994 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 134,000 MILES
Is there a bake back off screw to losen up the back brakes. If not how do you brake a stuck drum from the pads?
Thursday, January 17th, 2008 AT 1:23 PM
FLEXY5
  • 512 POSTS
Towards the top of the backing plate there should be an elongated hole that may have a rubber plug in it. Remove the plug and use a flat screwdriver or a brake adjusting tool to back it off.
Thursday, January 17th, 2008 AT 9:39 PM
