1994 Ford Explorer Brakes
XNENE347
Brakes problem
1994 Ford Explorer 6 cyl Four Wheel Drive Automatic
So i have a 94 ford explorer and i changed my front pads not too long ago but i dont have the rear brakes , and now when i press my brakes itt goes all the way to the floor, what can i do , i dont know the names of the rear brakes parts.
Sep 12, 2010 at 10:05 AM
  • 110,246 POSTS
Did you change calipers or open the hydraulic system for any reason? If not, have you checked for leaks?
If you opened the system or seen any leaks, chances are the master cylender is bad.
Sep 12, 2010 at 2:42 PM
