All three brake lights are not working on my 94 explorer. its not the fuse or the bulbs. Any Ideas?
Jun 5, 2008 at 6:10 AM
✓Experienced Mechanic
Find the brake switch on the brake pedal support. If fuse no.4 15amp is okay-you should have power to the brake switch connector light green and red wire-power here jump the connector with a small wire and see what happens to the lights, if it comes On replace the brake switch and adjust it-
