Auto locking hubs
117,000 MILES • 6 CYL • 4WD • AUTOMATIC
GRIZZLYEXPLORER
I own a 1994 ford explorer. It has auto locking hubs. Can the hubs be replaced with manual locking hubs from the same type of vehicle. I'm hoping. I am wondering if I will have to manually lock them in from outside the vehicle then push the button inside on the dash?
thank you
Sep 21, 2009 at 6:10 PM
  • 110,251 POSTS
Yes they can be replaced with manual locking hubs. And yes, you will need to lock them in then push the 4x4 button.
Sep 23, 2009 at 1:17 AM
FREDSANFORD1962
I'm changing the rotor out on the front driver side. I can't get the axle out far enough to get the spacer washer back on. The passenger side went well with no problems. I've pried and pulled with no results. I only need about 2mm more. The axle has no internal threads so I can't use a slide hammer. I'm at a loss and I need the car tomorrow.
Apr 28, 2020 at 6:15 AM (Merged)
DOCFIXIT
  • 18,828 POSTS
Look at diagram is problem plastic spacers?
DOCFIXIT
  • 18,828 POSTS
Sorry trouble with new site cannot attach diagram will try again
RWEMPIRE
93 ford explorer auto locking hubs makes clunking noise when making left or right turns
  • 110,251 POSTS
The factor auto hubs were a lot of trouble. chances are the gears in them are worn and slipping. If they need replaced, I recommend getting manual locking ones.
