Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
General
Fuse Test
1994 Ford Explorer air switch
1994 FORD EXPLORER
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
MARGARETY
MEMBER
my aircondtioning switch went off so i replaced the fuse and it worked for about 10 minutes and blew again. what could be causing this?
Jul 14, 2010 at 9:21 AM
Experienced Mechanic
Is the blower motor causing the problem or is it only when you put the AC on?
Jul 15, 2010 at 5:10 PM
MARGARETY
MEMBER
it only happens when i put the switch on the blower is fine, also i just had the air coditioner hoses ect relpaced and charged about 5 weeks ago
Jul 16, 2010 at 8:31 AM
My first checks would be wiring to the AC clutch and then the switch itself.
Jul 16, 2010 at 5:47 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
