1994 Ford Explorer a/c cycles
76,000 MILES • 6 CYL • 4WD • AUTOMATIC
GHOOVER
just bought 94 explorer , tried to charge a/c it took half a can until it said it was full a/c compressor cycles it does not stay on just cycles every 3 seconds air is not cold coming out of vents what could be wrong?
Apr 27, 2009 at 12:21 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:7d8328735b="ghoover"]Air Conditioning problem
1994 Ford Explorer 6 cyl Four Wheel Drive Automatic 76000 miles
just bought 94 explorer , tried to charge a/c it took half a can until it said it was full a/c compressor cycles it does not stay on just cycles every 3 seconds air is not cold coming out of vents what could be wrong?[/quote:7d8328735b]
Are you using a can that came with a gauge or did you already have a single gauge.
When it showed full were you still filling the system? If so reattach and close the valve down, the valve used to puncture can and see what it reads.
Apr 27, 2009 at 12:27 PM
GHOOVER
already had a guage , neighbor mechanic already had , and a can of 134a, read gauge while filling then took it of put it back on and checked it again
Apr 27, 2009 at 12:56 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:72c9c0c311="ghoover"]already had a guage , neighbor mechanic already had , and a can of 134a, read gauge while filling then took it of put it back on and checked it again[/quote:72c9c0c311]
And it read full?
Does the gauge appear to be accurate?
Check the Cycling Switch. Disconnect harness and jump the terminals, if the compressure kicks in and stays replace switch.
Apr 27, 2009 at 2:54 PM
