1994 Ford Explorer a.c
TEE 919
Air Conditioning problem
1994 Ford Explorer 6 cyl Two Wheel Drive Automatic 600ths miles
why does the belt keep breaking
Apr 25, 2009 at 3:54 AM
JGAROFALO
  • 489 POSTS
[quote:0f3621ce61="tee 919"]Air Conditioning problem
why does the belt keep breaking[/quote:0f3621ce61]
Among the possible causes are a frozen compressor, alternator, or idler pulley. You could also have a bent pulley somewhere. With the belt removed, check each pulley (except the crank pulley) to see that it turns by hand freely and easily. You should be able to turn each one by hand, and they should all turn without making any excessive noise.
Apr 28, 2009 at 11:38 AM
