1994 Ford Explorer 4x4 troubles
DJCRAZYJ
Noises problem
1994 Ford Explorer 6 cyl Four Wheel Drive Automatic
my 4x4 mechanism in my front axle is grinding and i want to know can the mechanism be removed without making the vehicle undrivable?
Nov 20, 2008 at 3:40 AM
BIGBLACK79FORD
i am assuming you are refering to the atomatic lockout hubs. if this is the case remove the wheels and remove the hub. you can then remove all the "innerds" of the hub and reinstall on the vehicle. doing so will allow the vehicle to be driveable but obviously you will lose 4x4 mode.
Nov 21, 2008 at 5:52 AM
MY68MONTERAY
  • 17 POSTS
if u don't want to lose your 4x4 capibility with winter coming up i would replace the hubs with new or used ones, it sounds like they are worn and do not engage completely
Nov 22, 2008 at 1:26 PM
