1994 Ford Explorer 4x4
224,000 MILES • 6 CYL • 4WD • AUTOMATIC
COLEMANCHRIS26
when I press the button on the dash for the 4x4 nothing happens. there is a light that is suppose to come on but it doesn't regardless of whether or not I am in park, neutral, moving or still. the light for the low range does nothing either. are there some things that I could check ?
Jul 29, 2009 at 11:29 AM
JGAROFALO
  • 489 POSTS
[quote:9e10c8529c="colemanchris26"]Transmission problem
1994 Ford Explorer 6 cyl Four Wheel Drive Automatic 224000 miles
when I press the button on the dash for the 4x4 nothing happens. there is a light that is suppose to come on but it doesn't regardless of whether or not I am in park, neutral, moving or still. the light for the low range does nothing either. are there some things that I could check ?[/quote:9e10c8529c]
The motor on the back of the transfer case has probably failed. Have a helper push the button while you listen underneath for the motor to run. Also check the electrical connector to see that it is fully plugged in, and that there are no wires pushed out of it.
Jul 31, 2009 at 12:26 AM
