1994 Ford Explorer 1994 explorer problems keeping it runnin
REYREY
1994 Ford Explorer Four Wheel Drive
replaced starter, battery is good. after changing starter kept engaging into flywheel and making the noise when you turn your key and its already started. now we bypassed the wire that was keeping it grinding in the flywheel so that it does not keep it engaged. but now it wont keep amps and truck dies???????????
Jan 7, 2010 at 3:42 PM
  • 75,988 POSTS
Check/test/replace the starter relay
Jan 7, 2010 at 5:28 PM
