1994 Ford Explorer
SMEEKINS
  • 1994 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 130,000 MILES
Engine turns over but will not start. We replaced the plugs and wires and the coil pack. The car is getting fuel. What else could it be?
Tuesday, April 27th, 2010 AT 2:28 PM
  • 109,755 POSTS
Did this happen all at once? Are you getting spark? Will it start for a few seconds with starting fluid?
Tuesday, April 27th, 2010 AT 11:21 PM
SMEEKINS
The car just shut down while I was driving no noises or anything. Yes there is spark but someone said not enough. We have not tried starting fluid.
Wednesday, April 28th, 2010 AT 12:30 AM
  • 109,755 POSTS
As far as the spark, it should be a blue snapping spark for it to run properly. Since starting fluid is more volatile and will burn easier, it may start with it. Let me know what you find.
Wednesday, April 28th, 2010 AT 6:31 AM
