Computer problem
1994 Ford Explorer 6 cyl Four Wheel Drive Automatic
I have no spark,and the fuel pump doesn't operate when I turn the key. The engine does crank,the battery,the ICM,the coil pack,and the crankshaft position sensor are new,however the engine still will not start. I do get oil pressure when cranking the engine,and if I'm right,that eliminates the timing belt as being the problem. Any ideas on what the problem could be?
Dec 14, 2009 at 6:45 PM
