1994 Ford Explorer
1994 FORD EXPLORER
231,600 MILES • 6 CYL • 4WD • AUTOMATIC
JMF_SPORTS92
My blower will only come on sometimes and it will only stay on for anywhere of a couple minutes to an hour or it won't come on at all. What can I do to relieve this problem? Because it is winter and I would like to have heat all the time.
Dec 9, 2009 at 6:47 PM
  • 110,194 POSTS
I understand what you're saying. Chances are the blower motor relay or resister is bad. However, to be sure, you need to check to see if the motor is getting power. If it isn't, then it's the resister or the relay. If there is power, then I would recommend checking for a bad ground. If the ground is good and you have power, then the motor is going bad.
Keep warm!
Dec 9, 2009 at 8:05 PM
