1994 Ford Explorer
200,000 MILES • 6 CYL • 4WD • MANUAL
TERRYDEYONGE
truck starts and runs fine for about 10 miles then starts to bog down as you press the gas. The harder you press the worse it gets until you have lost all power. Pushed in clutch turded it off and restarted. It ran fine again.
Aug 21, 2010 at 7:36 AM
  • 110,251 POSTS
Have you checked fuel pump pressure? Has the check engine light come on?
Aug 21, 2010 at 2:28 PM
