1994 Ford Explorer
130,000 MILES • 6 CYL • 4WD • AUTOMATIC
SMEEKINS
engine turns over but will not start. we replaced the plugs and wires and the coil pack.the car is getting fuel.what else could it be?
Apr 27, 2010 at 7:28 AM
  • 110,248 POSTS
Did this happen all at once? Are you getting spark? Will it start for a few seconds with starting fluid?
joe
Apr 27, 2010 at 4:21 PM
SMEEKINS
the car just shut down while i was driving no noises or anything.yes there is spark but someone said not enough.we have not tried starting fluid.
Apr 27, 2010 at 5:30 PM
  • 110,248 POSTS
As far as the spark, it should be a blue snapping spark for it to run properly. Since starting fluid is more volatile and will burn easier, it may start with it. Let me know what you find.
Apr 27, 2010 at 11:31 PM
