1994 Ford Explorer
KROB45
Brakes problem
1994 Ford Explorer 4 cyl Two Wheel Drive Automatic
On my 1994 ford explorer I 've replaced the brakes, calipers, rear shoes, master cylinder, power booster and bled the brakes, and yet
The pedal goes down to the floor and makes a noise and pulls to the right is there anything left beside the abs pump to change, the abs light goes off after engine starts
Apr 10, 2010 at 6:25 AM
  • 110,248 POSTS
The ABS shouldn't cause the pedal to go to the floor. Are the rear brakes properly adjusted? Have you checked the rubber brake hosed to the caliper? I've see them expand.
Apr 12, 2010 at 12:11 AM
